RE: Before posting, READ this, it MIGHT answer a question
does anyone kno if the EXCEEDMADSPEEDdrift cars are good there cheap thats the only reason i think they might not be that good, here are the specs and ****
Specifications:
Type: 4WD Electric Drift Car
Scale: 1/10
Length: 17.32 in (440mm)
Width: 7.48 in (190mm)
Wheelbase: 10.20 in (259mm)
Weight: 3.3 lb (1496.g)
Chassis: Molded composite
Suspension: Independent
Tire Type: Drifting rubber
Motor or Engine: High-performance 540 motor
Speed Control: Exceed RC engineered Speed Control
Radio: Pistol radio system
Servos: 3KG.cm high-torque steering servo
Kit/RTR: RTR
Shock Type: Aluminum, coil-over oil filled
Body: Prepainted 350 Drift body
Ball Bearings: Complete
Battery: 7.2v Ni-MH 1800mAh
features:
<ul>[*]Unique centralized low center of gravity design[*]Detailed side-view mirrors, wheels, wing and exhaust[*]Street-ready detailed 350 drift body[*]CNC aluminum upper deck[*]CNC aluminum center drive[*]CNC aluminum motor mount[*]Durable oil filled shock[*]Pistol Transmitter Radio Control[*]Exceed RC electronic speed control with 540 brush motor[*]3KG High-Torque steering servo[*]Foam bumper for added protection when drifting[*]Easy access front and rear ball differentials V[/list]
