ORIGINAL: rcdoug
Hi Frank,
I have a Rookie II set up on two 9303s. Everything works. I transferred the original to the second TX and everything worked. One needs to be slave and the other master. When I get to the shop, I will look at the exact trainer programming I have set up and re-post.
Doug
Doug's Hobbies
Bakersfield, CA
John, I was pleased to see this post for your cause, but I think 'rcdoug' mis-read Frank's question.
Send rcdoug an E-mail or PM to see/confirm that he truly has full capabilities on the slave as the master Tx.
Good luck [&:]
**EDIT** You fly them just fine, it's the helium within the wings that makes your balsa R-54 tough to land....
