RCU Forums - View Single Post - BME 115 Performance
Old 09-21-2010 | 09:28 PM
  #32
LanceLKs
Default RE: BME 115 Performance
The WB Carb would be a wb25.The wga7/9 is a much better running Carb. The falcon ignition is not worth risking your plane over. It is very unreliable. The plastic replacement Reed block had a problem of shrinking over time and led to the aluminum block which retains a little heat and lets excess fuel that puddles evaporate.
