Ok I have installed my Throttle linkage and Steering linkage,
I have tried to keep it a simple as possible and take up the least amount of space as I am using
Full size servos. I Used a IM clamp style Engine mount so I can get the ENYA out Easy with a Dubro Ball link on the Throttle,
there is not alot of room in the Engine bay or the tank area so I just used thin piano wire through a plastic tube, with a Z bend at each servo.
The fuel tank looks like a Problem, I am still thinking on this one.
I have started sanding and shaping my wing and will be doing the Ailerons next .....This is going to be a Pain in the A@#E [
Johnkpap
