RCU Forums - View Single Post - Kadet Senior
Thread: Kadet Senior
Old 09-22-2010 | 10:39 PM
JohnBuckner's Avatar
JohnBuckner
Default RE: Kadet Senior
ORIGINAL: shd3920
We will be using no bigger than a .46 2-stroke as we want it flying realllll slowwww.
In that case and since you are considering a kit then you need to adhere to stock and dont start throwing on the mods. Cover with film not fabric, do not modify with a two piece wing, do not add ailerons and use the stock gear I seen many that surprisingly when compared actually added weight by going to conventional gear with all manner of stuff and reinforcements. Built that way they are amazing airplanes and my favorite power is a two stroke 61 but a .46 does a fine job too if you do not fly at high elevations.
Here is one of my Kaydets (seniorita) in this case it has the perfect engine:
John
ID:	1505521   Click image for larger version
ID:	1505522   Click image for larger version
ID:	1505523   Click image for larger version
