RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Also interesting is the method of big end bearing retension.Rod end float obviously controlled at the little end and piston bosses.Are spacers used in that location?.
Looks to be set up for easy,straight forward bigend bearing/connecting rod replacement if necessary.Wonder if crank,rod,bigend bearing and crankpin are separately available parts.
