RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
On the 30 the rod is captive on the crank pin and is replaced with the crankshaft. On the 20 only the bearing is held captive on the crank pin, the rod will be able to be replaced separately. No spacers between the small end of the rod and wrist pin bosses in the piston.
