RCU Forums - View Single Post - DLE 20cc Gasser! (Data & Links 1st Post)
Old 09-23-2010 | 04:36 AM
  #636
airborne2.4
Default RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
ORIGINAL: a1pcfixer
Recapping the bits & pieces of info on this new engine, here's the
DLE 20cc gas engine details.......
Advertised weight: 29.2 oz with ign. and muffler
Prop range: 16 X 8 to 18 X 6
Rear Carb
Beam style mount
DLE20cc manual - compression ratio 10.5:1
Tower Hobbies - compression ratio 7.6:1
[Dimensions]:
Motor mount bolt spacing is 1'', case width is 1-7/8''
Distance from firewall to prop washer is 5-11/16''
From the center of the rear mounting hole to the edge of the open choke valve is 2-5/16''
Distance from propeller hub to the front of thr cylinder: 42 mm
Width of cylinder at exhaust port: 56 mm
Distance from the center line to the top of spark plug cap: 120 mm
(with spark plug cap fully inserted).
Prop shaft size : M8 x1.0 mm (w/two nuts)
[Ignition info]
Stock parkplug is a made in China CM-6 type (DLE 3)
Valley View R/C will include true NGK/CM-6
Electronic auto advance ignition
Ignition is a new model (#3) and special designed for this engine.
DLE recommended voltage range 4.8-6.0 volts
[Prop Data]:
APC Sport 16x7 9000 RPM 14lbs. 7oz.
JXF Beech 16x8 8300 13lbs. 10oz.
JXF Beech 17x7 7970 13lbs. 12oz.
SY 16x8 8500 13lbs. 5oz.
SY 17x8N 8200 14lbs. 9oz.
[VIDEO's];
[link=http://www.youtube.com/watch?v=lCHXY6_w6RY]Jody Haack - test flight video......[/link]
[link=http://www.youtube.com/watch?v=bBwqL9AIJ1U]First bench run (mpascualslp).......[/link]
[link=http://www.youtube.com/watch?v=kkwr_jc9HVA]and the engine response after 1 hour (mpascualslp)......[/link]
[Interesting comments]:
same mount size as OS 1.20
a 20cc is a drop in replacement for .90 to 1.20 size four stroke
more power than a CRRC Pro 26 or a Saito 1.25
20cc = 1.20 c.i.
30cc = 1.80 c.i.
[Warranty]
Valley View R/C; 1 year
Tower Hobbies; 2 years
[Ordering info....]
[link=http://www.valleyviewrc.com/DLE-20cc%20Gas%20Engine.htm]Valley View RC.....[/link]
[Owners manual]
[link={akamaiimageforum}/upfiles/22988/Ig11581.pdf]DLE20cc manual.....[/link]
Don't know how I forgot about this info
