Hello again Apache owners!
I would like to share my shopping list with you, in order to have some feedback on my selections. Suggestions and comments are very welcome!
<colgroup><col width="26" style="width: 20pt; mso-width-source: userset; mso-width-alt: 950" /><col width="143" style="width: 107pt; mso-width-source: userset; mso-width-alt: 5229" /><col width="148" style="width: 111pt; mso-width-source: userset; mso-width-alt: 5412" /><col width="451" style="width: 338pt; mso-width-source: userset; mso-width-alt: 16493" /><col width="42" style="width: 32pt; mso-width-source: userset; mso-width-alt: 1536" /><col width="77" style="width: 58pt; mso-width-source: userset; mso-width-alt: 2816" /><col width="86" style="width: 65pt; mso-width-source: userset; mso-width-alt: 3145" /></colgroup> | part | brand | model | qty | unit price | line price |
<colgroup><col width="26" style="width: 20pt; mso-width-source: userset; mso-width-alt: 950" /><col width="143" style="width: 107pt; mso-width-source: userset; mso-width-alt: 5229" /><col width="148" style="width: 111pt; mso-width-source: userset; mso-width-alt: 5412" /><col width="451" style="width: 338pt; mso-width-source: userset; mso-width-alt: 16493" /><col width="42" style="width: 32pt; mso-width-source: userset; mso-width-alt: 1536" /><col width="77" style="width: 58pt; mso-width-source: userset; mso-width-alt: 2816" /><col width="86" style="width: 65pt; mso-width-source: userset; mso-width-alt: 3145" /></colgroup> | HULL | MHZ | Mart's Apache WaveRider | 0 | | 0 |
| MOTOR | RCMK | New 520S motor | 1 | 500 | 500 |
| MOTOR | RCMK | Tuned Pipe 260 | 2 | 68 | 136 |
| MOTOR | RCMK | Sub Muffler | 2 | 37 | 74 |
| MOTOR | RCMK | Flus Header | 1 | 26 | 26 |
| MOTOR | RCMK | 90 Header | 1 | 26 | 26 |
| MOTOR | RCMK | Header Plange ST for 254 | 2 | 34 | 68 |
| MOTOR | RCMK | 0306000002 - Muffler End 2 | 2 | 11,2 | 22,4 |
| MOTOR | RCMK | 0204000011 - Long Venturi | 2 | 14,6 | 29,2 |
| MOTOR | HOBBY KING/TURNIGY | T1538B - Turnigy Compact Re-Buildable Fuel filter | 2 | 2 | 4 |
| DRIVE | WD200 | Z-Drive | 2 | 172 | 344 |
| TRIM TABS | WD200 | Trim Tab GROBE 2 | 1 | 53 | 53 |
| GEARBOX | WD200 | GETRIEBE 3 | 1 | 328 | 328 |
| SHAFT assembly | MHZ | 1093 - Flexshaft 1/4" | 1 | 17 | 17 |
| SHAFT assembly | MHZ | 1093/R - Flexshaft 1/4" CC | 1 | 17 | 17 |
| SHAFT assembly | MHZ | 1003/1 - Brass Teflon Tube 1/4 | 1 | 24 | 24 |
| SHAFT assembly | MHZ | 1011 - Brass tube holder 0,39" | 2 | 12,9 | 25,8 |
| SHAFT assembly | MHZ | 2256 - Flexwellensicherung mit Abfanglager 6,35 mm | 2 | 22 | 44 |
| COOLING | MHZ | 1585/P Water Pump | 2 | 28 | 56 |
| FUEL TANK | MHZ | 1924 - Benzintank 800ml mit Schraubverschluss | 2 | 39 | 78 |
| COOLING | MHZ | 1791/DM - Wasser - Aufnahme groß - doppelt METALL | 2 | 9 | 18 |
| COOLING | MHZ | 1795 - Kühlwasser - Auslass groß | 4 | 4 | 16 |
| BODY | MHZ | 1809 - Lift and Turn - Hauben Sicherheitsverschluss | 2 | 27 | 54 |
| BATTERY | HOBBY KING | TBD - 6v | 1 | 30 | 30 |
| SERVO | HOBBY KING/BMS | BMS-L530DMG+HS 1/5 Scale Digital Servo (MG) 19.8kg / .15sec / 140.5g | 3 | 25 | 75 |
| SEVO BOX | WD200 | | 1 | 30 | 30 |
| | | TOTAL | | | 2095,4 |
