RCU Forums - View Single Post - Flight training set-ups?
Old 09-23-2010 | 10:15 AM
rcdoug
My Feedback: (8)
Default RE: Flight training set-ups?
OK Gents,
I doubled checked the set-up by putting the Flash on the trainer.
Transfer your model from the master to the trainee's transmitter (using two 9303s)
Make sure the trainees transmitter is in ppm mode (I used a 72 mg tx for the trainer, 2.4 for the master))
Set BOTH of the trainer systems to "MASTER" ( I also set the slave / master bars to MAST on both)
Turn on the master transmitter, plug in the dsc/trainer cord, plug the other end of the cord into the slave transmitter ( do not turn on)
All controls, switches, trims should work. If they don't, double check your transfer.
That's it!
Doug
