RCU Forums - View Single Post - LT-40 Motor
Thread: LT-40 Motor
Old 09-23-2010 | 06:23 PM
jhatton's Avatar
jhatton
Default RE: LT-40 Motor
Just finished two test flights with this setup... No problems flying even fairly aggressively... with the 11*7 prop I currently have I have a peak around 800 watts as measured on the ICE controller with about 150-200 required to fly a level circuit. everything is coming down at about 100 degrees after a 10 minute flight so I think everything should be good. Thanks for your help on motor choices
