Converting landing gear question
The flexible gear & tri-cycle gear on a trainer is used for a reason & I think should be kept . He's got plenty of time for modifications later. The wire used on most foreign built ARFs is very questionable .Think you are much better off remaking the same gear as you have using a better grade of wire or like I said the next size larger . Happy Landing! MAX H.
