Converting landing gear question
I've seen guys replace wire gear with aluminum just as you propose, but they still get the same problem from the occasional rough landing. Going to aluminum puts you in a slightly stronger class, but the same class none-the-less. Also, I believe it is harder to realign the aluminum and get proper camber once it is bent.
I have no direct experience with them so take this with a grain of salt. Does sound reasonable though.
