RCU Forums - View Single Post - Crazy Prop Vibration
Old 09-23-2010 | 09:36 PM
Lnewqban's Avatar
Lnewqban
Default RE: Crazy Prop Vibration
LS88,
I agree with the above posts.
Rotate the propeller position on the shaft and give it a try.
Check if the problem happens with any propeller.
I have seen some propellers not having the hole and the plane of rotation perfectly perpendicular, which creates strong vibrations, regardless good balance.
Also check for a slightly bent shaft of the engine.
