RCU Forums - View Single Post - G-62 lite
Thread: G-62 lite
Old 09-24-2010 | 08:30 AM
  #49
CGAV8R's Avatar
CGAV8R
Default RE: G-62 lite
ORIGINAL: BadAzzMaxx
Talking about getting criticized.
A little over two years ago I built a thrust stand that you could mount a plane in and test thrust with different props.
Was at a fly in and was having some fun with it, Tested a Area51 with a 23-A Vess prop and a DA with a 23-A Vess prop, The Area51 put out 2lbs more thrust than the DA at the same RPM
Had the video posted on U Tube but got so much slack about it I removed it.
We did the test three time to make sure nothing was wrong, So showing people thrust test does not seem mean squash .
Milton
Ok, I'll bite. How is it possible for the exact same prop at the exact same rpm produce two different thrust calculations?
Aaron D.
