RCU Forums - View Single Post - Really, how imp is balancing your 12" prop?
Old 09-25-2010 | 10:45 AM
Lnewqban's Avatar
Lnewqban
Default RE: Really, how imp is balancing your 12
1) I believe you did all you should. I would verify all linkages as well.
2) You could balance the prop; however, I suspect a bent engine's shaft due to the bird collision, since the spinner doesn't turn round.
