RCU Forums - View Single Post - Moding Homelite 25cc - Input Appreciated
Old 09-25-2010 | 04:42 PM
spede18's Avatar
spede18
Default RE: Moding Homelite 25cc - Input Appreciated
Iam scarred Imight mess up the piston if I try to pin it myself.
Iknow you can use a welding rod as the pin, anything else that can be used?
What size drill bit would I use to drill out the piston and would Ineed to use a dril press?
Obvioulsy Idon't drill all the way thought just enough to seat the pin.
Iplan to get a ring from him when Ipin the piston.
