RE: ELMOD GUYS IN HERE PLEASE
You would have to play it from you tube and record it as a wave file. Then go through the process explained above to capture to the EL mod hardware.
I will be doing the same. I want Taps or Amazing grace to play once the tank is put out. I doubt I can find any wave files, so I will have to try it by recording if on the computer. Quality will drop off a lot through this process.
