RCU Forums - View Single Post - Engine For Kwik FLi Mk. III
Old 09-26-2010 | 02:55 PM
  #41
Taurus Flyer's Avatar
Taurus Flyer
Default RE: Engine For Kwik FLi Mk. III
ORIGINAL: NM2K
ORIGINAL: R_G
ORIGINAL: Johnkpap
OS Gold head's will turn almost anything in the 60 size prop range,
mine works best with a Master Airscrew 12 x 6
I found that a 12 x 8 made landings too exciting [X(]
My light weight ugly stick just would not slow down enough at idle with a bigger prop
Johnkpap
Thanks for the prop info Johnpap! [sm=thumbs_up.gif]
ORIGINAL: ntsmith
Enya make a superb .60 sized job. Didn't Phil have a liking for Enya ?
BTW its not cheap but a superb piece of engineering tha will outlast - dare I say it - even an OS.
I know Enya's are great performers, I've had several, but I think Phil selected the Enya for the Kwik Fki for it's size and weight rather than it's performance. I could be wrong about that, but I seem to remember reading something along those lines.
ORIGINAL : Patrnflier
I used a Kraft .61 in mine and it flies great.
I had to be creative on the mount and did this: Engine Mount http://www.fancyflying.150m.com/fuselage%2010.JPG
Here is the finished install: Finished Engine http://www.fancyflying.150m.com/QF%20Rfront.JPG
Here is my build supplement: Kwik Fly Build http://www.fancyflying.150m.com/qwic_fly_iii_build.htm
Cheers,
Marty
Thanks Marty! I actually came across your build supplement a couple weeks ago while surfing. Great stuff! [sm=49_49.gif]
These engines were designed to fly pattern. As such, they were designed to turn 11x7 to 11x8 props only. No 12'' anythings, unless you're interested in overheating the engine, losing ring tension and just having an average .60 on the front.
It's early and I'm crabby. Sorry for the 'tude. <G>
Ed Cregger
Ed,
Be careful, the whole world is reading with you.
The K & B 45 RC was a wonderful engine, I did tell it often before. With 75% of engine volume the engine not even did have a ring, but you could became world champion with it!!
See picture 1
Cees
