RCU Forums - View Single Post - Got my LT-40 completed
Old 09-26-2010 | 06:36 PM
Augie11
Default RE: Got my LT-40 completed
A 10x7 or 11x6 prop should do the trick. I'd go with the 11x6 on an LT 40. You're not looking for speed.
Leave the ailerons active. She will fly much better with them. Once you're comfortable with her you can try flying her with just the rudder leaving the ailerons still connected. You will actually find that the LT will fly better using both ailerons and coordinated rudder in the turns.
Good luck with the maiden flite!
