RE: CG Setup and fuel level?
If your not using a fuel pump, you'll need to mount the tank directly behind the firewall.Balance without fuel...Yeap adding filling the tank will effect the CG, making the plane slightly nose heavy.For general sports flying this shouldn't effect the pleasure.Set it at the 125 mark and see how it goes.
