RE: CG Setup and fuel level?
Hi!
4" from the firewall will not work!!!! You must mount it against the firewall! And mount it according to the tank mounting rule.
Most engines use silencer pressure but that still isn't enough for coping with the various tank pressure situations. As for the C of G! This is allways dialed in using an empty tank as most airplanes are in the tractor configuration (Engine up front).
