RCU Forums - View Single Post - Building the Flea-Fly
Old 09-28-2010 | 03:35 PM
  #47
Johnkpap's Avatar
Johnkpap
Default RE: Building the Flea-Fly
Hi Nigel
How is the covering going ?
Did the solar film hinges work well or would it be better to use CA hinges ?
I have finished sanding the wing and cutting out the Ailerons, It worked out to be easyer than I
thought it would be, I made up my Conrtol horns buy cutting down some SIG horns (SH-694)
these are a close match to the ones used on the plan.
I decided to go 1:1 on the bellcrank this gives full movement of the ailerons, I can reduce the servo's
movement in my Futaba radio if the Ailerons have too much movement when trimming the plane.
My Flea fly is getting there I have alot of finishing on the fuse before that is ready to cover.
Johnkpap
ID:	1508105   Click image for larger version
