RE: DX7 Flaperons
Dangaras - They each have an aircraft with a servo for each Aileron and using the Flapperon mix. They just want the Flap switch to drop the Ailerons as Flaps.
The procedure you just outlined is for an aircraft where the Ailerons and the Flaps are separate control surfaces (two Aileron servos and two Flap servos).
