Satio 180 Muffler Fixed (I hope)
For What It's Worth
I plugged the original hole with JB Weld and a small screw type clamp.
Up near the muffler inlet the aluminum is much thicker than at the bottom. It is on a bit of an angle. I drilled and tapped a whole for the 8/32" pressure fitting. I used Locktite to hold it.
Have 12 flight on it so far with no problems. The engine ran just fine.
Anyone see a problem with having the pressure fitting up near the inlet to the muffler?
RSN
