RCU Forums - View Single Post - warbird replicas hurricane
Old 09-29-2010 | 04:09 PM
gary132
Default RE: warbird replicas hurricane
Firewall now bonded into the hurricane. i found with the sc80 engine i will be useing the forewall position is good. i used triangle stock behind the firewall to strengthen it.
[img width=533 height=400]http://i172.photobucket.com/albums/w28/garyflyer/Hurrican%20build/DSCF4133.jpg[/img]
the exhaust stubbs fitted to the cowling and blisters.
[img width=533 height=400]http://i172.photobucket.com/albums/w28/garyflyer/Hurrican%20build/DSCF4132.jpg[/img]
Litho plate fitted to the rear of fuse to simulate metal plateing.
[img width=533 height=400]http://i172.photobucket.com/albums/w28/garyflyer/Hurrican%20build/DSCF4131.jpg[/img]
next i chose to strengthen the wing fillets with glass clothe and resin. i covered the wing section with plastic to stop the resin sticking everything together. this can be trimmed off when dry.
[img width=533 height=400]http://i172.photobucket.com/albums/w28/garyflyer/Hurrican%20build/DSCF4134.jpg[/img]
