WARNING dont make my mistake i fitted firewall upside down here . i fixed it later with a mod.
Firewall now bonded into the hurricane. i found with the sc80 engine i will be useing the forewall position is good. i used triangle stock behind the firewall to strengthen it.
the exhaust stubbs fitted to the cowling and blisters.
Litho plate fitted to the rear of fuse to simulate metal plateing.
next i chose to strengthen the wing fillets with glass clothe and resin. i covered the wing section with plastic to stop the resin sticking everything together. this can be trimmed off when dry.
