RCU Forums - View Single Post - Roll Trim Problems
Old 07-29-2003 | 05:02 PM
crotts
Default Roll Trim Problems
"what servos are you running on the wings? "
Futaba 3004s
how do the wings attach?
single piece wing, dowels in front, bolts in rear. BTW, have tugged on the wing to see if it is loose, and it is seated firmly.
how are the ailerons fixed on landing are they cocked one up and one down?
Yes, but only in the amount that is trimmed in.
does the wings have any noticed flex to the eye or twist?
No, checked that already and had atwo others look at that as well.
has any of the wires show any signs of the wire inside showing does the pull pull ofr thorottle cable rub any of your wiring?
Throttle cable isn't rubbing, but I haven't done a thorough inspection of wires, will do that tonight.
Neal
