RE: BVM/UP retract valves
Hi Jon
On my Bandit I have been using the standard BVM valve, with a button valve to close the doors, and a servo slow function to sequence it all. This has worked perfectly for three years now, and is the simplest system I have come across.
I used to ue a UP valve and found it was a bit fiddly to set up, but once it was set up itworked fine.
Roger
