Internal layouts for Phaeton 90
I'll be doing my maiden on a P90 in a week or so. I used a 16 oz tank with saito 120 up front. Also used a pull pull system for the rudder. The servos for rudder and elevator are under the cockpit. I also used a tiller for the pull pull instead of fastening directly to the servo. Aileron servos are in the wings and went with 4 ailerons. This was a swap meet plane I got all framed up for $35. The wings were straight and the fuse and empenage were straight also. Just a few broken pieces from hanger rash. Its covered with solartex and painted with rustoleum and clear coated with lusterkote gloss. I debated moving the elev and rud servos further forward because I needed more nose weight. 2 packages of led from the hobby shop. But all in all, its not that bad. Overall weight is 13 lbs 4 oz. I will fly it as a slow aerobatic plane anyway. So keep that in mind when mounting equipment. But remember, you might want to put rec and battery under the servos. You might cut off access.
Edwin
