RCU Forums - View Single Post - CA Technique With Servo Mounts
Old 10-01-2010 | 10:30 PM
Lanzfeld
Default CA Technique With Servo Mounts
We all know that to make servo mounting holes tougher we should put thin CA into them and let it dry before we insert the screws. I always assumed that you should:
1. Drill the hole
2. Screw in the screw
3.Back out the screw
4. Then put in the thin CA in that order.
My latest ARF kit says to put the thin CA in BEFORE you ever thread the holes with the screws. It seems to me that you want the threads in thereBEFORE you harden up the hole so this seems backwards to me.
Am I correct? Why would this ARF say to do this?
