RE: Micro DH2
This is the upper wing....it is 1mm printed depron.
This is printed straight to the foam after it was airbrushed with Inkaid.
We thinned the inkaid about 50% water 50% inkaid. Furthermore I didn't weight before because I coated a whole sheet of depron then cut three 14"x13" sheets after it had dried. If you do a search on inkaid someone has this information.</p>
</p>
