RE: CA Technique With Servo Mounts
I agree with opjose It depends on what wood you using not everyone uses plywood or hardwood servo bearers.
I use balsa sticks for servo bearers in many installation and I generally will coat the spot with thin CA first to harden the surface then pilot drill and run the screw in.
John
