RCU Forums - View Single Post - CA Technique With Servo Mounts
Old 10-03-2010 | 01:46 PM
Rodney
Default RE: CA Technique With Servo Mounts
I have always found I got the best results (this is for 4-40, 6-32, 8-32 and 1/4-20 size bolts) by first drilling the proper size hole, run in the tap, remove tap and apply CA, give time to set up CA, retap and then insert bolt.
