ORIGINAL: mike109
G'day The main advantage of using a lower pitch prop on an overpowered model is to allow the model to slow down when the engine is idling to let you land more easily.
For this reason I usually use 5 pitch props on my trainers.
The AX 46 will happily spin a 12 x 6 (a friend has quite a heavy model of a PC-9) flying really well with this combination) so a 12 x 5 would be a good start. The engine will happily swing the 12 inch prop and this will keep the revs and the noise down too. Or you could try an 11 x 5 as well.
There really is only one way to find out. Try some props and see which you like.
For that .46AX I'd also recommend an 11x5 or a 12x5. It would depend on ground clearance. An 11x4 just sounds like too little a prop (pitchwise) for this engine and you risk over-reving.
