Plane does not want to land
I'm posting this here because I'm not sure where the best place for this is.. but anyway,, I have an EF Yak with a DL50 in it. My problem is that when I slow it down to land the nose of the plane floats up and it does'nt want to land.. I have it a little tail heavy for 3D flying, It flys hands off at a little less the half throttle. Is the plane being a little tail heavy causing this? The nose of the plane goes up just enough to make it float and not want to land. I have to force it down and then cut the throttle to get it on the ground. Thanks for any help you can give.
