Ignition Glitching
I just put a 26CC engine in my plane. I have found that when doing a range check (72 mhz) with the antenna down and engine NOT running, everything works well up to 100' or so. When turning on the ignition switch, I get glitching of several control surfaces around 70'. Can't figure out why when the engine is not running. Any thoughts or potential solutions to eliminate glitch?
Thanks.
