RCU Forums - View Single Post - Skymaster T 38 Problem
Old 10-04-2010 | 05:52 PM
kevinthoele
Default RE: Skymaster T 38 Problem
Anton,
Got the parts. they sent only the end of the piston with o-rings. This solved one side of the leak but not the side with the piston sticking out. Can't believe the did not send the whole cylinder as reported.
Thanks to Jeff, He is forwarding new cylinder from F-5 kit that is the same.
Hopefully we will be ready when this one comes in.
Anton,
Skymaster should add one more step in manufacturing process and have each cylinder tested by putting air on each side of piston and listen for leak. Mine was such a large leak that all air is gone in 5 seconds from 100psi filled tank.
Question from earlier about the inlets. They are rounded like the full scale, not an F5 turned into a T -38
