RCU Forums - View Single Post - Plane does not want to land
Old 10-04-2010 | 09:49 PM
cfircav8r's Avatar
cfircav8r
Default RE: Plane does not want to land
ORIGINAL: millertym2000
I have to let the plane Idle as low as it can to get down with out having to force it down, When theres no breeze it will float in like a trainer but when theres a breeze it makes it hard to get down because I cant let it just float down ,, I will try and put in some down trim on one of the switches and see how that works. I like to fly my planes in instead of floating them in, its just a little hard to force this one down..
As long as its not gusty you can "float it in like a trainer". The problem you seem to have is when you have wind your ground speed will slow and your angle of descent wil increase making it seem like its falling out of the sky. With some practice at altitude on breezy days you will find it will still flare and touch down smoothly. The slow steep descent looks a lot worse than it really is. The thick wings need to slow down or they will balloon when you try to flare.
