RCU Forums - View Single Post - drilling holes in balsa
Old 07-30-2003 | 07:09 AM
nashtm
Default drilling holes in balsa
Hi
copper tube as mentioned above works well - I use the metal part of a shotgun shell for large holes - the trick is to separate the plastic tube from the metal part without deforming it - I use a heat gun turned up high.
Tim
