drilling holes in balsa
To drill a hole in balsa without tearing the balsa. Turn the drill backward Most drill presses will not turn backward so you will probably need to use a hand drill that is reversable.
I have never tried to drill balsa by reversing the bit direction, but I do have a set of reverse drill bits, used for drilling out broken studs.
This will allow me to use my drill press, I will give it a try.
