RCU Forums - View Single Post - drilling holes in balsa
Old 07-30-2003 | 09:03 PM
tdemaio
Default drilling holes in balsa
You should certainly use the sanding drum for final finishing if possible (depending upon the size of the drum and hole).
Drilling a small hole that a small rotary rasp/file can enter might well be the first step of a three step process--use the rasp to enlarge the hole big enuff for the sanding drum as the second step.
always,
tony
