RE: Extreme Flight 88
It's a good idea to soak these block bases with thin CA. I had the 87" Yak and the blocks loosened. With this one I put plenty of thin CA on the bases and they have not loosened up after two years. Another thing is make sure to lean the low end as much as you can so it doesn't shake so much at low RPM's.
