ORIGINAL: alpiani
Hi,
Order number yhst-17210252890263-138012 . Before putting the plane together i checked all electronics. All worked fine, except esc. It would cut of the power to the motor, make weird noises, reset all the time, shut down even at half throtle, it just wasn't working properly. I took the esc from my other samef-16 that i bought from you almost a year ago and problem was fixed. If it's possible could you send me a new esc. It was 25A with heat sink. Thank you.
Hi again. I wrote that message in a forum a while ago and still didn't get a reply. I thought i'll try again. Thanks
