RE: Servo tray
Does this tray have the plastic lugs that the servo grommets push through instead of using the servo mounting screws? I believe the eylets will not let the plastic lugs fit through the servo mounting holes. I would think you would not use the eyelets. The way the tray is designed you use just the grommets and then take the plastic "V" and put it over the plastic lugs to clamp the servo in place using one screw on each side instead of two mounting screws.
