RE: pte 50
Could you tell us what is different about the spark plug and reeds.
Below is a picture of a DLE/DLA and other type engine reeds.
I know there is another style made that is made out of plastic with a rubber gasket holding the reeds in place, The trouble is sometime when installed the rubber will not seat right and cause the reeds to stay open.
Does the crank to prop hub have a taper fit or is it straight with no taper
I can see it is using the old style 50cc DLE cylinder.
Milton
