RCU Forums - View Single Post - Ignition Glitching
Old 10-07-2010 | 08:31 AM
pe reivers
Default RE: Ignition Glitching
ORIGINAL: DennisS
I just put a 26CC engine in my plane. I have found that when doing a range check (72 mhz) with the antenna down and engine NOT running, everything works well up to 100' or so. When turning on the ignition switch, I get glitching of several control surfaces around 70'. <span style="font-size: larger">Can't figure out why when the engine is not running</span>. Any thoughts or potential solutions to eliminate glitch?
Thanks.
Hey folks, pls read!
