RCU Forums - View Single Post - Tamiya TRF 801XT Build Thread
Old 10-07-2010 | 10:47 PM
Eman77's Avatar
Eman77
Default RE: Tamiya TRF 801XT Build Thread
In the next pic, you can see the diff gasket ready to go, next to the diff fluid and half-built differential. The second lousy pic is a blurry rendition of the fluid inside the differential housing. And finally, the completed differential.
Not pictured is the fact that Tamiya has you put a rubber o-ring around the part of the diff cup that goes inside the diff, and then a pin through the shaft. The mid-sized gears inside the diff then sits upon that. Tamiya also provides a grub screw in the side of the differential cup, for you to drain fluid from (and insert one of the above pins easily!).
I would have snapped a pic of that, but I just thought of it. Tough nuggets.
ID:	1512537   Click image for larger version
ID:	1512538   Click image for larger version
