RCU Forums - View Single Post - Tamiya TRF 801XT Build Thread
Old 10-07-2010 | 10:54 PM
Eman77's Avatar
Eman77
Default RE: Tamiya TRF 801XT Build Thread
And here we go putting the differential inside the housing. The input pinion has a spiral cut gear of course, to match the ring gear. The diff housing will clamp together with one rear screw, and a ring clamp that goes over the "nose" of the housing. You'll see pics of that later, once I get to it.
The Tamiya manual called for grease (ceramic, I inferred, since that's the only grease they supplied) between the ring gear and pinion. That doesn't make sense to me, as ceramic is for plastic/plastic really. Molybdenum is typically for metal to metal contact, so I might use some of that I have around.
For now, it's getting a bit late, so I'll continue in a day or two with the build, and this thread.
TTFN!
