25LA Problem
The O.S. Max LA-series of engines have bushing-supported crankshafts. If you use an electric starter, you're basically jamming the crankshaft back against the rear cover. This will make it difficult to turn the engine over. Use a starter stick and hand-prop the engine. It should start up nicely.
